h_lankford
- Joined
- Aug 6, 2005
- 135
Please advise. Am replacing water pump on LU of 1986 Johnson 3 cyl 60 hp. Decided to replace shift rod O-ring on the shift rod cover, too. The O-ring resides in a circumferential groove cut midway in the inside of the shift rod bushing. <br /><br />Manual says unbolt shift rod cover (done) and remove O-ring. For installation of new O-ring, manual is equally short on details. Just talks about being careful to slide and turn the lubricated shift rod down into the new O-ring. But I haven't gotten that far yet.<br /><br />So to replace the old O-ring, do I ?<br />Remove the old O-ring with a suitable hooked wire or other jury-rigged device?<br /><br />And for installation of the new O-ring, do I slide it up or down the inside of the bushing with a 5/16" wooden or plastic dowel (or butt end of a 5/16 drill bit) until it pops into the groove? Seems straightforward, but I don't want to mess up.<br /><br />Thanks for any tips. Harvey
