Replace OMS pump with aftermarket or Original
Chris1956
My 1998 Johnny 150HPV6 has the original OMS pump. It is working fine, however, It has been 25years or more since new. Should I replace it as a part of PM and if so, should I use a rebuild kit ($195), an aftermarket one ($150) or an oem part for $600?
flyingscott
You can rebuild it but I don't know if I would trust the oil side. Aftermarket are garbage. I would pay up for the OEM one and keep the oiler. If you dont want the oiler Go with the aftermarket double pump. .
Chris1956
Thanks for the reply. I do like the auto oil injection. I guess I am flying off the idea of a rebuild for $200 vs an OEM pump for $600.
Your point about the oil side is valid, since there are no rebuild kits for the oil side.
