Glassparman
- Joined
- Sep 10, 2002
- 29
I'm working on a 1962 Glasspar Ventura; a 21' Cabin cruiser and I'm considering what to do with the transom.
It was originally an outboard but I'm converting it to an I/O. The transom seems real strong and does not have any rot visibly showing. The only problems I see is the plywood is slightly depressed where the old outboard mounting bolts were.
I know I need to add on to the outer fiberglass which is not a problem. The question is should I just add on to the plywood core or replace the entire core? It was obviously a longshaft configuration and the outdrive will be mounted well below the top of the existing transom.
Ideas??
Ideas??
