Replace Outdrive Shift Cable?
pyrotek
I am going to be ordering parts to replace the shift and u-joint bellows. I am reading about a lot of people replacing their shift cables at the same time. I have no known issues shifting. Would you recommend replacing the shift cable as preventative maintenance? I don't know how often they fail.
Engine is 97 7.4L. Most likely never been serviced, but I really have no idea.
Engine Serial Number: 0K035983
Drive Serial Number : 0K094390
I'm attempting to order everything that I likely need to replace. I may have to order additional items once I take it all apart, but I'm trying to order everything in advance if possible.
Hinge Pin Tool
U-Joint Bellows
Shift cable bellows
Gasket glue
Oil Hose (I can't find part number for this). Do I need any additional connectors?
Trim Sender Kit (mine is not working)
Thanks
