Re: replace shift shaft seal
Points are 20 thousands of an inch. Timing should be pretty static and not need adjustment. If so 28 BTDC is the spec. How to find that is beyond me. Hopefully someone else here can help with that. I remember reading a merc thread that stated that because of the use of unleaded fuel that timing should be set at 31 degrees instead of 28. Good luck.
