Easy Touch
- Joined
- Sep 21, 2021
- 2
Hi, I have a 1992 4hp Johnson 2 stroke and I am looking to replace the stop button on the front with a kill cord button. At present the stop buttons has 3 wires going into it, 1 black/yellow then 2 black. One of the black wires is connected the housing and then the other 2 wires run to the ignition module. The kill switch I have is a 4 terminal, so one pair of terminals is closed then open and the other 2 are the opposite when the kill cord is removed.
Am I right in thinking that I can connect both black wires to one terminal on the kill switch and the black/yellow to the other. Then when the cord is pulled the circuit with be completed and the engine will "ground out" to stop?
Many thanks
Many thanks
