The question I have is can I replace/swap the entire ignition system on my 50173s 50HP Evinrude with the ignition system from a 74 50442M 50HP Evinrude? This would include the stator, power pack coil assy, and timer base assy. I noticed by doing a parts search the power pack, timer base assy, and stator has a different p/n and is not used from one year to the other refering to 71 & 74. The flywheel and coil assy are the same p/n. The motor cable on the 71 is yellow in color with more pin connectors and the 74 is red with less, but it looks like the motor cable connects to the terminal block. I notice the stator on the 71 is 6 amp but not sure what the 74 is amp wise. What would be the difference in the power pack sice they have different part numbers?
Like I said I have the entire ignition system off of a 74 and wondering if I can put this on the 71 50HP.
I had started another thread a few days ago titled 1 doggy 71 Evinrude with a tick. That will explain the issues I'm having and why I want to know if this will work.
I also noticed on the crankcase there is a safty switch assy. that has a electric wire ground) from it to the smaller terminal on the slnoid, was wondering if that is for the electric shift. Someone ran a seperate ground wire from the slnoid to motor ground. when I disconnected the added ground wire the motor would not crank so obviously the switch is bad. is this important or just a safety feature. And yes safety is important.
Please help maybe someone has done this or I'll be the first.
