I am in the process of replacing the Trim hoses on My SX-M Outdrive. The problem is that I have ordered the parts as below, but If I install them as on the exploded view, the STBD side hoses are not fitting properly (nearly kinked). 3853855 is installed up in the manifold and on top of the cylinder and 3857524 down in the manifold and lower on the cylinder. Is this exploded view correct?( STBD side hose on top of the cylinder = upper fitting in the manifold, lower fitting in the cylinder = lower fitting in the manifold)
Also feels a bit strange that on the port side the hose 3853857, which is installed on top of the cylinder, goes on the lower fitting in the manifold.
Please advice how the hoses should be installed on the manifold?
Thanks in advance!
Thanks in advance!
