Replaced Impeller in Yamaha 200 Now Stuck In Forward Gear
jcbache
I replaced the impeller in my '94 Yamaha 200 Salt Water Series and now I'm stuck in Forward gear. Starts in gear and stays in gear. Pulled the cowl and I can see that the shift lever is attached and seems to be working properly from the controls ( I'm by myself so I can only observe from the control while I work the shifter myself.) I'm thinking that somehow the shift rod isn't lined up properly? Any help would be greatly appreciated! Thanks
99yam40
drop lower unit again.
put lower in neutral along with putting the controls in neutral also
put back together
