Replacement hubs
Havasu bound
Re: Replacement hubs
I have a Rapture 14.25 x 17 SS. The original hub had some kind of epoxy or ? You can buy the kit, just wondering if theres something special that needs to be done.
QC
I'm always Havasu Bound too . . . Welcome aboard!!
You need to look into what style hub you have. If it is a Flo Torq style, then there is absolutely NO epoxy, so that note is confusing. If it IS a Flo Torq, then DIY is actually kind of required or you will never know how to replace a prop. Basically, if your hub falls out in your hand in multiple pieces, you have a Flo Torq style. If everything except the thrust washer, prop nut and the locking stuff is sort of one piece then you need a prop shop to replace your hub system.
Flo Torq style:
images
