Replacement ignition switch
mustafawahab
I have a 2011 Party Barge PB20 with serial # BUJ10401J011.
The ignition switch moves from OFF to RUN but when I push and twist the key clockwise it will not move to START. The switch is a sealed assembly with a harness that terminates into a grey plug.
Basspro identified the switch as PN129572 and want $120.53 plus tax and shipping for it.
Is there a reasonable secondary market source for this switch?
Does anyone have a wiring schematic that identifies the wires in the harness so that I can replace this mysterious switch with a standard ignition switch?
Thanks
belairbrian
Re: Replacement ignition switch
What motor and remote control/throttle do you have? Is the switch in the dash or in the remote control?
GA_Boater
Is the boat still in warranty?
ZachDean
This helped me when replacing my switch. Hope it helps you out.
