iloveketchup
- Joined
- Dec 4, 2010
- 54
If it was my boat, I would remove the drive completely. Since you don't know the condition of the shift cable, now is a good time to find out.
With the outdrive off, disconnect the shift cable from inside the boat. From the outside, move the cable full stroke by hand. I should move smooth and very easy. If not, time to replace it. While the drive is off, make sure there isn't any water in the bellows, the ujoints and gimbal bearing are in good shape, the alignment is ok, and last but not least that the splines on the shaft going into the coupler are greased.
It is your intermediate shift shaft that needs to be replaced (#22 here http://www.mercruiserparts.com/Show...0065.png&inbr=2203&bnbr=60&bdesc=BELL+HOUSING). It is located in the upper part of the outdrive, so you need to remove the outdrive and split the upper and lower halves. When you put it back together the shift shaft slides onto the splines of the lower shift shaft (make sure the lower ss washer is in place). Make sure your control handle is all the way forward and that the lower ss is turned all the way clockwise (prop locks when turned CCW), and the top of the replacement shaft is pointing straight ahead to mate with the upper ss coupler. Good luck
i'm pretty sure this isn't the way the Merc manual says to remove the stern drive, but i didn't have the tool to remove the cover and screw with the u-joint nor am i going to remove engine mounts.
worked out fine, doesn't appear anything was broke :shrug:
it looks like the bellows were in okay shape... at least okay for someone else to worry about it in a season or two. Things were awfully greasy. I've never had one of these off and out.
What the hell have you done ???????
If it takes a tractor to pull the upper away from the bellhousing, you have either done something wrong, or there is some serious problems inside. That drive should have fell off the back of the boat.
I pity the poor fool that buys that boat from you
Ok, the control handle is all the way forward. the c channel on the bell housing is straight foward. isn't this neutral? If i take a wrench and try and take it (looking from underneath) to the right (pointing towards port side of boat), it won't stay.
does the outdrive have to be in forward to remove it?
this thing is just sticking... i know it's been off within the last year.
No that is forward. The reason you have to have it in forward when you pull the outdrive is so that the top of the intermediate shift shaft will slide straight back out of the "C" channel connecting it to the upper ss. N is 1 position CCW and R is 2 positions CCW. It won't stay because the shift cable holds it in place.
Yes. Except in your case since the top of the intermediate shift shaft is gone, it does not matter :facepalm:.
From the looks of the bellhousing I am not surprised LOL.
