Replacement prop won't seat
Status
Not open for further replies.
redgoat
I am trying to replace a damaged prop on my Mercruiser IO 153, 4cyl, 120hp. The replacement prop (#48-76012-21) will not slide in far enough to expose the shaft splines so I can fasten it down properly with old nut. The prop stops just short of exposing the splines. The old prop had a number of 48-30012-21. I don't want to force or hammer it on further. But something is not right. Even though I have had this replacement prop for probably 30+ years, I don't think it was ever installed and put into service. Do I have the wrong replacement prop? Will it ever go on properly?
Fishermark
Re: Replacement prop won't seat
There are different thicknesses of the thrust washers - (I think that is what they are called). You might want to post this in the prop forum.
EddiePetty
...or, you just may have installed the existing thrust washer backwards!!!! :)
DBreskin
I saw you also posted this in the prop forum. Please don't double post.
Oops, I saw someone suggested you go to the prop forum. My bad, I should have read the whole post first.:redface:
Status
