Replacement prop
natsgrampy
I have an 87 Sea Ray 200. It has a 3.0 Mercruiser I/O. The propellor was dinged and I would like to replace it. Trouble is, I have no clue what to look for. The current prop is SS and has the following on it.......T15320. I don't know what the numbers mean and could use some help identifying the correct size prop
Mac525
Re: Replacement prop
please read the sticky post to see all the info we need to help
natsgrampy
OK I guess what I am wondering is what do the numbers on the prop mean. I don't know the manufacturer of the prop, only those #'s and that it is Stainless steel. I would like to replace it with same size but don't know how to read the #'s. I mean the # is T15320. Is the 15 the diameter and the 20 pitch.?
Robbabob
My search of the internet did not turn up anything for that string of numbers (probably what you already tried). Since we don't know the size to tell you exactly, we are stuck with trying to get a rating on what you should have. See this link http://forums.iboats.com/showthread.php?t=287818 and fill in what you remember about the performance before the damage. Also, you can have your current one repaired for less money and then have the repair shop tell what it is.
Good luck!
