Replacement Seat Bottom Material???
thompsdw
Our Ray has a removable seat in the transom pass-through. Some time ago, one of the kids was standing on the seat and the starboard base failed (no shear strength at all). Given the fact that I want to put something with more strength back in place of the starboard, what should I use?<br /><br />I have to be able to staple into the material and it doesn't get exposed to moisture too often. Any ideas?
Re: Replacement Seat Bottom Material???
Plywood........
cuzner
I used 3/4 inch plywood.used old piece for template.Use stainless staples if you can,and make sure sand and bevell plywood to prevent wood from tearing vynl.<br /><br /><br /> Jim
thompsdw
I assume that any exterior glue ply is fine? I will probably paint it to match the other seats.
Yep.....
