nymack66
- Joined
- Aug 5, 2009
- 356
I will like to install a warning horn on my engine, I currently monitor my engine in a way I happy with 2 independent senders and gauges. I never trusted the Horn 100 percent since it can fail or in some cases not work at all.
Someone pointed out whilst my current set-up is good, as an additional layer of protection I should install a horn and attach it the OEM senders (which I have but not connected) in this way I have something audible just in case I am not paying attention.
In my opinion its a very good point, so now I will like to implement it, however I was wondering if I can use something other than the OEM expensive horn since its use as second fiddle in this equation? or should I just install the OEM version?
