Hello,
I have a 97 350 with an Alpha drive, that has a bad alternator. I purchased a 105Amp single wire Delco alternator and have a couple questions about replacing it.
From the wiring diagram and some things I have read online, the Orange wire (See pic) is the positive wire, and goes over to the starter. It connects at the starter to the positive side of the battery system and does it's thing.
If I replace the current 3 wire with a 1 wire, can I just connect the old Orange wire to the single post on the alternator? Or should I run a new wire from the alternator to the engine side (not battery side) of my battery switch?
My second question is, if I just connect the orange wire, is it large enough to handle the increased alternator size? I think the old alt was 55 or 65 amp, where this one is 105A.
At a minimum I will cap off the other two wires.
Engine:
ENG:* 0K282550* 4350100KS* 1997* MERCRUISER* TB5, W/PS, TWOPCEX, WORO* 350* ALPHA*
Engine:
