Replacing a Ficht Fuel Injector?
donny822777
I am currently rebuild ing a 200o model Ficht 115hp outboard. It had water in one cylinder which got in through the injector and there is now rust and corrosion all over the injector. I have purchased a used injector and am getting ready to put it on and try it out. I have heard that the injector should come with a cd for programming? Is this necessary? Any help would be greatly appreciated. I have rebuilt around 100-120 outboards in the last 4 years but this my first fuel injected engine. I could use some advice from a real pro like the guys on this forum.
Thanks Again
wilde1j
Re: Replacing a Ficht Fuel Injector?
Each injector has unigue data which must be transferred to the EMM. Do not try to run the motor w/o doing this! You will need to get this from the seller and you will need BRP sw to effect the data transfer.
