NEED TO REPLACE PLUG ON THE CORD OF ON ELECTRIC CLOTHES IRON. Cut off old plug not realizing that one prong is wider than the other. Now I do not know which way is correct to install new plug. Took the back off and found the ends of te wires where they connect to the heating element. Tried to determine which one is ground using ohm meter. Neither one showed continuity from wire to ground. Of course I do not know what is ground since everything seems to be plastic. Even touching to bottom plate did not show continuity from either connection. One terminal has a very small diameter wire in addition to the cord wire running somewhere. I wonder if this terminal should be considered the hot wire or terminal? Any help in wiring this correctly will be greatly appreciated. Sorry for the long post-just trying to be thorough.
