Replacing a sliding leaf spring...
floater180
Hi All,
Has anyone had any experience replacing the leaf springs on your trailer? How hard is it and approximate time it takes to install both sides of a single axle trailer. Please advice.
Thanks
siggyrocks
Re: Replacing a sliding leaf spring...
It can be done fairly quickly if the boat isn't on the trailer.
I've have a bit of experience changing leaf springs on 4x4's.
I always go with new u-bolts so i just cut the old ones off.
Same thing with the mounting bolt. Cut off the head and drive the headless bolt through the spring and mount with a punch.
Careful, the u-bolts are under tension and will pop and release energy so be careful you aren't in the way when they let go.
Proselect
I would say if you are pretty mechanically inclined it should take only about two hours. I can whip them out in an hour or so if everything comes apart good, which I never count on. I just took my springs and axle out of my trailer when I painted it. I also suggest new u-bolts as well. I ended up replacing the 4 bolts that hold the springs in as well. If you don't want to replace the bolts at least change out the lock nuts. Once a lock nut is removed it usually won't lock anymore like it is suppose to. When I did mine I had two u-bolts that I had to cut. One of the bolts had to be cut, and one snapped off.
dwco5051
Less than 1 hour if you own a cutting torch. The previous posts are right on the money with their answers. Be sure to have new bolts and U-bolts on hand. Not only shouldn't you reuse the old ones but if you plan on doing it you will bugger at least one up and have to go for a new one anyway.
floater180
Wow! It didnt take long to replace my springs. The other question is I installed a spring rated for 3000 lbs as the trailer is rated but I only have a little over an inch of suspension play. Is that right???
redone4x4
sounds about right. Remeber the ST tires are made to absorb some of the shock as well as the springs.
