Hello gentlemen,
I know there are a million different ways to do anything but I would like to hear some thoughts on the best way to replace a transom on an aluminum boat.
1. Material - I've read different things about exterior grade plywood and marine grade plywood. What is the difference? Do they both need to be sealed? Is one better than the other?
2. Laminating - Two pieces of 3/4" plywood laminated together seems common. What is the best method of laminating these pieces? Type of glue? Type of screws?
3. Sealing the wood - If you are going to seal the wood what is the best product? Epoxy? Fibreglass resin? Brand names? What is the best method? What is the best way to seal the holes where the motor mounts etc?
If you were going to replace a transom on an aluminum boat and wanted to do it right, how would you do it?
