Replacing a Volvo SX Outdrive with dual prop
air0msw@yahoo.com
Was wondering, I have a volvo 5.7 with SX outdrive on a 26' cruiser. Can I replace it with a dual prop volvo outdrive? Would it bolt up to the transon plate for the SX outdrive? What benefits would I get by doing this? Appreciate all info.
mcleaves
Re: Replacing a Volvo SX Outdrive with dual prop
It's a direct swap.. Best thing I ever did. You will NOT regret it.
Pros:
Lower planing speeds
Better Top End
Handles like tires on pavement around the docks
Cons:
Prop sets are 600.00+ for aluminum, over a grand for Stainless
air0msw@yahoo.com
Do you replace both the upper and lower cases or just the lower section of the unit?
Ayuh,... i believe Only the lowerunit is different....
Don S
Just the lower has to be changed.
The 5.7 requires a 1.95 gear ratio.
air0msw@yahoo.com
One last question, what size props would it need? It is a 2001 Glastron 26' cruiser with a 5.7 currently using a 15 X 17P prop on the SX outdrive. Looks like the props for the DP are sized by F2, F3, etc. Which one should I use? Thanks in advance.
Don S
That would be a good question for the prop forum.
mcleaves
The F's are Stainless and the D's are aluminum. After that, as Don said, you're gonna need to talk to people in the prop forum I think. I have a 24' Express cruiser that is about 5500 lbs wet. I run a 5.0 (well tying to - see my other threads ;) ) and the D5 and D6 work well for me depending on my application. The lower the number the smaller the prop set.
