Replacing a VRO with a Standard Fuel Pump in a 1997 50 HP Johnson
chriswdavis
I am needing to replace my VRO fuel pump on my 1997 50 HP Johnson (Model Number: J50ELEUR) with a standard 3 port fuel pump.
What replacement part(s) do I need to get to make this switch?
I need to get this fixed.... I'm having fishing withdrawals...
Thanks for the help,
cd
There is a spot on the # 1 cylinder to mount a pump directly over the pulse port with a gasket..---Remove the plug between the screw holes.--Then plug the pulse port that was used for VRO unit.----So you just need a pump with 2 hose fittings.-----Fuel in and fuel out.
