replacing alternator
formula351
Hello i have to replace the alternator on my 351 mercruiser, what type/ size alternator should i get?
DHPMARINE
Re: replacing alternator
I'd replace it with the same as you have.Just be sure it is a marine unit.Maybe a local shop can rebuild it for you.<br /><br />DHP
blouderback
It MUST ABSOLUTELY be a marine alternator. DO NOT try to replace it with an automotive type. Marine alternators (and other marine parts) are designed to reduce spark, which automotive parts are not.<br /><br />In any case, Overton's should have a replacement. Look for some part numbers and/or amp rating on the old one.
formula351
does anyone have an idea what amperage the the alternator should be?
prowlersfish
62-65 amp in most cases you can use up to 70 amp<br />that will bolt up if you have a nando( ??) you can replace it with a delco but the main thing <br />it must be for MARINE USE !
ron7000
Banned
here's where I bought mine a couple years ago,<br />haven't had any problems with it although you may want to paint the outside of it when you get it otherwise it'll look like crap after 1 season.<br /><br />I have a model 233 merc with the 351.<br /><br /> delco 10si 2 inch foot
