Re: replacing an old water pump
On the three that are above the Anti-ventilation plate, you might be able to either split the nuts with a nut splitter, or use a dremel tool with a cutting wheel to cut thru the nuts. You should be able to open up the split with a cold chistle, and get the nuts off. The nuts under the A-V plate should either come off with some force, or the stud will unscrew from the midsection, or they will break. The bolt under the zinc trim tab will probably just break or strip. I think your real issue will be to get the driveshaft to uncouple from the crankshaft. If so, you can hang the motor upside down and try to blast the driveshaft with some penetrating oil, and pray.
