Hi, This late Fall, I need to replace my block. 5.7 liter 350 SB. The base engine I will get has the block and heads. (Vortec). I will reuse the rest of the parts from the existing motor, 1 year old. Bad winterizing. My question. When transferring the distributor, should I mark it and set it in a particular way, so as to get roughly the same position on the new engine? Thanks Roman
This is a 350 5.7 L Vortec with fuel injection.
