Re: Replacing bearing on bevel pinion - lower unit
Yes. That is a straight sided hole as shown in the third photo. The old bushing can be driven out downward and the new roller bearing can be driven in from the top or you can go the other way.. BE CERTAIN to use a correct sized tool when driving it in and DONT get too aggressive with the hammer. You can bend the outer shell and jam the rollers inside the bearing. The new seal can also be simply driven back into its seat with care.
The pinion bearings do come in a number of sizes and the best way to buy one is off the numbers stamped into them. HOWEVER: ALL bearings are standardised and if you bring the complete bearing/pinion assembly to the bearing supplier, they can measure the pinion hub and give you the correct one.
I had cut down the length of the bushingbefore I investigated buying the bearing. This bearing is the middle of three different lengths.
AS I said above, getting the bearing off the pinion will not be an easy job unless you have specialzed bearing pullers, but it can be done. Typically, when I do it, I wedge something under the cage and rollers . This does destroy the cage but will usually get me enough room under the bearing race to pull it off. Just don't expect to do it in 10 minutes.
If I had an extra pinion/bearing assembly, I would offer it to you----but unfortunately I don't.
You can see the comparison between the stock bushing and the roller bearing. I also included a comparison of a 50 HP pinion and a 25 horsepower pinion. You can see that the hub is the same size even though the bearings are different and the splined hole for the driveshaft is different.
