Replacing bleed lines on 71 Merc 800
Moody Blue
As part of a rebuild process I will be replacing the bleed lines (if that term is correct) that run between/from/to different parts of the block. I believe they re-circulate lubricant to the main crankshaft bearings.
Can I use clear fuel line to replace the original black lines? The original lines were hard and brittle but still intact.
