Replacing connectors on speed/temp sensor
burroak
I have an Eagle Trifinder II sonar/fish locater with a speed/temp function. I have a LEI speed/temp sensor ST-TBK and want to adapt a connector that will hook up to the Trifinder. The ST-TBK, which is for older Lowrance (I believe) is black and has a 4 female layout. The TS-TX (same sensor unit as TX-TBK) has a gray connector. I can make up my own connectors; hard wire the sensor, since it's not coming out of the boat as long as it is alive; or try to cajole Lowrance out of a ST-TX connector. Anyway I slice it, I need the wiring diagrams for but the ST-TX and ST-TBK cables.
Can any of you McGuyvers out there lend a hand?
Silvertip
Re: Replacing connectors on speed/temp sensor
I'm not sure if that cable is shielded but if it is, you'll need to work around that issue. Other than that there is no reason you can't splice in theoper connector.
