Alright, so I've been looking around this forum as well as a few others and I think I've got a pretty good idea what I need to do, but I'd like to make sure I've got the sequence of events down right first. I only want to have to do this one time
<br /><br />Description of events so far:<br /><br />First the boat is a 1976 Glastron T-166. It's the exact boat pictured here. It's almost 30 years old now
The floor got soft and I don't want to part with this boat. So this past weekend a friend and I tore out the floor, which was actually fairly easy since the wood was so rotted. The hard part was cleaning out all the debris to make sure it would drain properly after the floor is replaced. We ended up removing the gas tank b/c debris was getting caught in front of the rear drain and it was the only way we could reach the place that needed to be cleared. The area we're replacing is about 5'x8'. So, it's all cleaned up now and it needs to be restored.<br /><br /><br />Now the questions:<br /><br />1. What are the chance the gas tank is still good? It wasn't exposed to the elements at all. It looks perfect from the outside, but I'm concerned about it's inside. I believe the tank is aluminum, but it's had the gas/oil mixture sitting in it unmoved for about 5 years. Would this have comprimised the tank somehow? And if so, where would I find a suitable replacement?<br /><br />2. I know from reading old posts that I should be using marine grade plywood. Where is a good place to get some? I'm in the Dallas area if anyone knows lumber yards around here. Also, is there a minimum thickness I should use? The old plywood I pulled out appeared to be 1/2" but everything I've read on this board's old posts say they used 3/4". I'm not sure I could make 3/4" fit under the front deck lip that sticks out a little bit where I need to put the wood.<br /><br />3. As far as prepping the wood....I think I've read that I should put two coats of epoxy resin on the wood before I put it in place. Is that accurate? I think I read that I should mix the resin with some sort of thickener. Is that right? And I thought I saw someone say you should put down some fiberglass cloth between layers, too. Is that right or should I wait until the wood gets put in place before I put any fiberglass on it? And, should I still use the epoxy resin when putting the fiberglass cloth on or is there something else I should use? And how many layers of the fiberglass cloth should I put on after the wood is in place in the boat?<br /><br />Sorry for the long post, but I want to only have to do this one time. Any suggestions, would be appreciated. I've been taking pics all along if anyone wants to see them or if it would help you make recommendations. I don't mind reading, so if anyone's got some webpages with walkthrough's or something. Thanks in advance.
