1988 GM 3.0L 4cyl Mercruiser, Alpha 1 outdrive. <br /><br />Can somebody tell me the correct and easiest way to install my distributor once it has been removed and engine timing/position is not known.<br /><br />I cannot get it to start and am sure this is the problem. I took it to the lake today and it idled ok, if a little hard to start. Once in gear and throttling up it would constantly miss/skip then run great for a second then bog again. It was running fine last week but I had problems with starting when hot so I replaced plugs, points, condenser, rotor and cap, leads and also replaced the fuel filter @ the carb and added a fuel/water filter. I removed the distributor to fit the new points and thought I replaced it in exactly the same place but now I am not sure and also think I have messed up the timing as it won't start at all at the house. When I serviced as above I set the dwell and then timing and thought everything was ok until I hit the water.<br /><br />I am desperate to get this thing running as my wife and kids are flying home from a months visit to England and I have taken the week off work to spend some family time at the lake!
<br /><br />Any help with timing would be MOST appreciated.
