1.) Does anyone know a trick to remove the drive shaft seal from this motor's lower unit housing? .....I dont have a tiny puller (if there is such a thing).....I saw a Youtube post of a guy that drilled a hole in the seal and used a pair of vice grips to pull it out...I'm a little worried about drilling a small hole and not damaging the brass bearing underneath,,
Maybe a piece of all thread or something.....I don't know yet...
2.) I bought a gearcase seal kit.....the kit has a couple of seals that look loke thedrive shaft seal....
Does a gear case seal kit generally include a drive shaft seal ??
Thanks
Thanks
