I have a 2003 trophy 2359(~24ft 6000lb) with a 5.0L Mercruiser and alpha genII that is almost exclussively used in saltwater. I have been underpowered since the day I bought the boat. The engine now has no compression on a couple cylinders so instead of putting money into repairing a 9 year old underpowered engine, I plan on upgrading the engine. I wanted to go with a 2012 5.7 MPI Mercruiser but can find no one that can provide a full fresh water cooling option, only a half system. The engine compartment has very little space to work in so want to avoid having to replace manifolds in 5-10 years. I am now looking at the indmar 5.7 MPI which comes with a full fresh water cooling system(including dryjoints). I want an injected engine for the convenience, horsepower and improved fuel economy. My alpha genII is geared at 1.62, I am also plannig on replacing the upper to 1.47(thinking SEI). The Bravo conversion would be nice but would like to keep a few dollars in the bank.
Looking for advice on my plan. Also contemplating doing the work myself but cannot figure out how I would get the engine out and back in. I do my own maintenance work on the drive so that piece should not be too hard(I assume a SEI upper and a Merc lower work together) . But how challenging is it to line up the engine correctly (assuming I can find a hoist)? Is there a lot more to it than getting it lined up and bolted down? Thanks for the help.
