Re: replacing floor need tips
Cosander, <br /><br />For measuring, run a string down the center of your boat, and mark off every 6 inches or so. Transfer those measurements off a centerline on your plywood, and that'll make a template. Test fit, etc., till it fits to your satisfaction. Or, if you can grab some cardboard that's big enough, you can make a template from that.<br /><br />For a bit of info on epoxy and glass, take a look at this post:<br />
http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=26;t=004745 <br /><br />Or, if that link doesn't work, scroll down to "Marine Carpet Glue Over Epoxy Resin" posted on May 12.<br /><br />As far as epoxy goes, it's pretty easy to work with. Use old clothes, and definately gloves. You'll be throwing them out when you're done. <br /><br />Some epoxy brands are a 50/50 mix, some are different. Just mix it together, and roll, brush, or squeegee it out, and make absolutely sure you really get it into the edges. When dry, add another coat, working the glass cloth in. <br /><br />Lastly, there are tons of topics on replacing and/or repairing flooring in the forums. Keep searchin' and you'll find more info than you can absorb in a year!!!<br /><br />Good Luck<br />Rick
