nickjack69
- Joined
- Apr 30, 2009
- 9
i need some advice on the easiest way to change out a freeze plug on a 5.0 mercruiser motor. the motor is still in the boat.
Howdy,
The easiest way to replace them is to punch a hole in them and pry them out with a screwdriver.
Drive the new ones in with a mallet and a deep socket or other driver that just fits inside them. Use brass replacements.
By the way they are not "FREEZE" plugs. They are core plugs for the casting process.
If they popped out because your block had water in it and it froze you may have bigger problems.
Great disclaimer
will i need to pull the motor to get to it.
