Re: Replacing impeller on 1977 merc. 1500
I replaced the impeller today, and getting water thru' the pee hole now. Old impeller was beyond bad, no flabbers at all. Motor is good, easy start every time. Don't know how she will do on the water, as nothing is hooked up yet.
I am going to rewire the internal harness wire so that I can use the existing external wiring harness on the boat(from existing control box). New to me
power tilt and trim will need to be installed as well. The 175(refer to my other post) has 2 hoses, and the 150 has 4. Planning on removing the powerhead on the 175 after that since I found out that all my spark plugs were in good shape with no metal shavings or deposits. Might have thrown a rod or bearing, don't know! Was able to turn flywheel 1.5 turns before it stops. How do you know what the problem is???? Plan on rebuilding if possible. Cylinder 5 has been bored out on last rebuild. Where or how do I start on this project???
