I'm about to replace the impeller in my Volvo Penta 5.0 GL. Seems to be a relatively simple DIY project. However, after buying the part and reading the instructions that came with it, I have a little more concern.
This may just be typical warning type info. that comes with most products, but I wanted to be sure I don't screw something up. It's talking about the potential for getting air trapped in the system which will prevent it from operating correctly and could damage the pump/cooling system.
First question....how typical is it for that to happen, and is there an easy way to help avoid it?
Second question....it says to be sure that the pump is drawing water within 30 seconds of starting it back up or to shut it off right away if it isn't. How can you tell if it's drawing water?
