Re: replacing manual to 12V power winch
#2000 of pull would certainly work, but what is at issue is how winches are rated.
Winches are rated with the spool empty. By the time you get all the strap / cable back on the spool, the winch might only be capable of supplying 1/3 of its rating.
In a manual winch, this loss of pull manifests itself as you needed to crank harder and harder to get the same amount of pull out of the winch. On an electric winch the input power is fixed. You can?t crank harder and harder to maintain the necessary pull. You just start running out of power. If the winch is not properly sized, the load will just stall the motor and burn it up.
My boat weighs roughly the same on a roller trailer. I have a #4200 winch on it. The winch really strains the last 5-6' of travel. Really needs a #6000 winch.
Calculations and recommendations from an earlier post
http://forums.iboats.com/showthread.php?t=420390&highlight=dingbat
