Replacing Mercruiser with Car motor
cruiser4
I am trying to match up a car motor to flywheel housing #865657A04, its for a mercruiser 4 cyl. 120 hp, it was used on different motors from around 1970 to 1990, so does anyone have a template or the bolt hole measurments for this housing so I can match it to a motor, thanks.
D
DJ
Guest
Re: Replacing Mercruiser with Car motor
You won't find a match. The MerCruiser 4-cyl. was first used as an automotive engine in the early 1960's. After that, it was/is an industrial engine only.
JaseBosto
So, your trying to put a car engine in a boat, replacing the 4 cylinder? I doubt it would hold up long.
Ayuh,... The Chevy bellhousing bolt pattern is/ has been the same since 1955 or so...
But,...
That won't be your Problem...
180shabah
...and just what engine are you trying to jury-rig in there?
JaseBosto
But,...
If bondo and myself are thinking along the same lines, as said a car engine won't hold up. There is a good reason why they call marine engines......marine engines.
Fishermark
Actually, not to speak for Bond-o, but the bigger issue is simply that the 120 is not found in cars. The 120 and the 140 are interchangeable, but the 140 (3 liter) isn't used in cars either. As mentioned above, it is found in industrial applications (fork lifts, etc).
The problem isn't as simple as "a car engine will not work" - because many engines are in fact used in both cars / trucks and boats. The 350 is a prime example. Nothing special that makes it a "marine" engine except the cam, core plugs and head gasket. (And the externals of course - but I am talking about the long block).
Back to the original poster's question - don't get confused with the engine many call the "Iron Duke" - it is not the same.
cruiser4
Sorry I am new to this forum and boats and I am in Canada, isn't 120 hp the same as 2.5L engine? I have a cracked block on my 120hp mercruiser and I'm looking for a block to replace it, so couldn't I use a 2.5L engine block and replace the cam, etc...as long as the flywheel housing matched the block.
Nope,.. The 2.5l used in cars is in no way even Close to the marine motors...
Totally different castings... Not even the same engine family...
Those are the Iron Duke Fishermark speaks of.. It's a Pontiac motor...
180shabah
Did that 2.5 come from something in the 60's? If not, it's not a match.
cr2k
Start checking Craig's list or see if there are marine recyclers (wrecking yards) in your area.
Don't know where your area is but there are several in CA as well as a few MC 4 bangers on CL.
You could go with a V-6 but then you have motor mount and bellhousing issues as well as the need to change the gear ratio in the outdrive.
JaseBosto
I thought marine engines had beefier internals as well, for running at WOT for long periods of time.
2stroke1971
Totally non helpful comment, but as far as going the other way, I know of some dirt rack racers who have used marine parts in building their race car engines because of the differences!
Overnighter20
When you pull the engines (Chevy) apart you'll find that the part numbers are all the same. (Except the cam.) Lots of urban myth out there on this and yes, some buy in to it.
Years ago I had a 21 ft GW Hatteras with a 165 mercruiser, which is nothing but a 250 inline chevy six. I replaced it when it got tired with a short block from carquest, for around $650, and built it up with all the externals from the original. Everything bolted up perfectly. $650 for a brand new 165 hp i/o ain't a bad deal. Damn thing burned about a third less gas than my buddies 150 ocean pro too. I miss that boat.
Overnighter20
I actually have never seen a boater run at wot for long periods of time. Would annyone do that with their tow vehicle or family car? what's the difference?
Friscoboater
The 305 and 350 are the same as an automotive engine except for the differences listed above. I had one custom built for my boat and just added the drain plugs and called it a day.
180shabah
...they believe all the BS about being built better than a truck engine.
jasher32
The 2.5/ 120 is a GM 153 found only two years in the ChevyII as a base model engine.
firecapt13
I called Mercruiser and talked with a tech. He said when hey get an engine from GM all they do is replace cam and freeze plugs. He said valves, heads and block assembly are all the same.
