glennj3
- Joined
- Sep 6, 2011
- 381
I have gotten the bellows off, at least 2 problems though I found no holes in the bellows.
The shift cable needs replacing, at the outdrive the housing is rusted apart with rusted wires showing in the housing. I can get a new one, do I need a special tool to get the old one off?
Next at the gimbal housing where the baffle slides on in front. It has a chip at the bottom about an inch long, located on the lip. It looks like that piece can be turned with a special tool and replaced? I think the bellows will in fact slide over and past that chip, but then that may be where the water came from. I don't think there was any bellows adhesive on any of them.
Lastly, do I need a special tool to remove a ring that seems to be holding the large gimbal bellows on at the outdrive section.
