Anyone attempt to remove the impossible needle seat on the older Merc 9.8 carbs and retrofit them with another matching set? I've attempted to clean this sucker multiple times and each attempt results in the problem with the needle sticking causing no gas to get to the motor. I can pump that sucker super hard and tap the float cup and it still stays stuck in there. When I take it apart the needle is usually sucked in really good in the seat and the float is bone dry. I changed the needle already and that hasn't helped the problem.
Andre
Andre
