Re: replacing omc cobra outdrive
I just had mine on and off a few of times (not all the way bolted on with gasket but at least set on there all the way) because after it was rebuilt the shift linkage was out of whack. So I got a little practice.<br /><br />On mine it took firm pressure at the right points, finess at others, and finally a good kick for that last 1/2"<br /><br />The first time I did it I got to that last point and for the life of me I could't get it. I was honestly so ticked off that I leaned back on the wall called it a four letter word and kicked right on the cover over the water pump. Low and behold it popped right on, or at least enough to get the top to bolts started then I could push down a little bit and the bottom slipped in.<br /><br />This was after making sure it was aligned, with new o-rings that we properly oiled, and the "kick" wasn't hard enough to really break anything but it was pretty firm.<br /><br />On later tries I found that it worked every time. I also found out that while the cursing may help, it wasn't required ;-)
