Merc90HPnewbie
- Joined
- Jul 27, 2003
- 178
Ok here I go again with my beginner questions. I spun out the hub on my old prop but luckliy the boat came with a spare new prop. The splines on the new prop were kind of corroded (the prop was stored on the boat) and I used a brass brush to get the green powdery stuff off. I was going to smear a bit of the waterproof grease (Trailer axle bearing grease) in the prop when I read the container which said "do not mix greases of different soap types". Not knowing what was on the old prop and shaft I sprayed it down with brake parts cleaner and got the old grease off. Then I relubed the driveshaft and new prop with the waterproof grease and reassembled. When I had the old prop off I noticed a very fat washer behind it. Behind that was a hollow area with a zerk fitting.<br />So my question is, what does this fitting lubricate? And how often should I lubricate it? Also with the warning about not mixing different greases how do I make sure all the old stuff is out (of wherever it is this fitting goes to) before putting in new grease? Or do I not worry about that? How do I know when I've filled it to capacity?<br /><br />Thanks!<br />oh PS it's an 85 Mercury straight 6 cyl 90 horse
