Replacing remote control 2004 Horizon 200
Hi all,
The control took a dump last Sunday. The center button for throttle became stuck and we had no gears. I took the shifter apart I don't know if the spring is sprung or if there's something stuck in the works that's preventing it from springing out completely. I've bought a replacement that "appears" to be compatible with the original as it seems OEM is obsolete. I could not find a part number on the OEM anywhere. I took several pictures of the way the shifter was assembled and didn't disturb the cables at all. Is there anything I need to know to not screw this up? Or did I already screw it up?.
Thanks.
