Replacing seats....
notinbig
Has anyone pulled out the back to back and put in a captains bucket? is it easy, seems like it would be? Not cheap I'm finding though.<br /><br />Thanks ya'll
crazy charlie
Re: Replacing seats....
I have seen plenty of them on ebay.The install is a little tricky because it has to be anchored properly or you will find yourself laying in the stern the first time you throttle up.Charlie
notinbig
So I'll need to have an anchor? I thought I could use a base that takes 8 screws all around it?<br /><br />??? :confused:
Yep, Exactly,<br />Trick is getting it Securely Mounted........<br />Without Driving Screws Through the Hull........ :D
Aahubb
I am planning to do this too. My idea is to place a piece of plywood under the deck to reinforce the pedestal support.<br />.. Aaron
cjflanagan
Funny how things read, it sounds as though you plan to screw through the hull too.<br /><br />BP212
