navigator336
- Joined
- Jul 27, 2003
- 270
Have any of you replaced shaft packings while the boat is in the water? I won't need to haul the boat for bottom painting for another 2 years but one packing is nearing the end of it's adjustable range. My thought is to dive under the boat and press molding clay around the shafts were they penetrate the hull to create a temporary seal while I remove the old packing material and replace with new. Conceptually this seems sound (assuming I remember to remove the clay),but I may be overlooking something and there is probably a better way to do it. I would appreciate any tips on the best way to remove the old packing material given that I have limited clearance between the v-drives and the packing gland (abount 8 -10 inches to work with). I would also welcome thoughts on whether to use the old tried and proven flax based packing or the new teflon based materials.<br /><br />Thanks.
