Each time I come here with a new question means I have successfully fixed, replaced, or determined my problem from the previous question. I would call that great progress thanks to you folks.
Anyway the question. While I have the outdrive off the boat I wanted to fix the skeg. When I got the boat a good portion of it is missing. So is it better to buy a replacement skeg and have some one weld it on or will one of the bolt on skeg protectors work just fine? Then ones that I see are stainless steel. Will the difference in metals cause a problem?
They both seem to cost about the same but I can work a screw driver. Welding is out of my hands.
Thanks guys and gals.
Hal
Hal
