Hi all. I've been reading for a couple hours here. What a group! I've learned quite a bit about replacing floors, but still have a few questions.
It's an inboard ski boat. The motor cover hinges attache to a fiberglassed piece of decking that just rests in the center-rear of the boat by gravity. The flooring section on either side of this were soft so I took a battery skillsaw, set it about 3/4" and cut approximately 1" from the side. There is a sort of bulkhead or box running along the bottom of the gunwhale. Once I cut 1" from that I was able to pull the rotten plywood out leaving a 1" flange of glass sticking off the side. There is foam in this section of the floor. I haven't decided if I need to replace the foam or not. But the foam is not high enough to provide any support for the decking. I guess the outside edge of the floor was only held by the fiberglass layer that came across the top? The other side of the section to be replaced will rest on top of the stringer. I've read that you can screw/epoxy that to the stringer. I just don't know how the other edge will be supported.
Also I hear references to epoxy and mat. Can this be bought at Home Depot?
Here's a picture of the section I cut out.
http://www.floridavotersguide.com/greg/sideview.jpg
And here are my new seats ready to go in!
http://www.floridavotersguide.com/greg/newseats.jpg
Thanks in advance for any help.
Greg
Greg
