Replacing some key things on my trailer!
evilnss
So i found out over the weekend that my trailer brake lines are missing a good few inches from rust! So i can only imagine what the brake them self look like...
I'm thinking about buying this:
http://www.etrailer.com/Trailer-Brakes/Titan/T4843100.html
It says it has an electircal bypass for reverse and such, and when backing the boat into the water, I usually disconnect the electrical. So would this become an issue? And if it has an electric lockout, do you t hink it would have a manual overide as well?
Also the leaf springs are pretty rusted too. Im looking to replace those as well.
dockwrecker
Re: Replacing some key things on my trailer!
That looks like a great kit! I just did all of that with Kodiaks from Champion and I'm in mine $650.
bruceb58
Personally, I would not use any of the Titan disc brakes. Kodiak only!
The Titan stainless version I bought were horrible. I have heard problems with the non stainless versions as well.
bruceb58
Who makes the brakes? if they are Kodiaks they are good.
RWilson2526
I dont see it in the picture but I'll bet your master cylinder will have a pin that you can slide in to manually lock out the actuator. Being that you are only disconnected electrically when at the ramp I dont think you would have a problem anyway. Being that the whole rig is angled down you probably wont be engaging the cylinder enough anyway to lock up the brakes.
bruceb58
If it were my boat, I would get the back up solenoid valve. It just sucks getting out and disabling them sometimes.
As far as unplugging when launching, I never unplug. I have sealed lights so not a problem.
