Captain Caveman
Ensign
- Joined
- Mar 1, 2005
- 958
This is for a 1957 Johnson Seahorse 3hp (JW-13). One of the spark plug wires is bare to the wire in a spot. I've got the flywheel off and have new wire, but am stumped about how to swap out the wire. Do you just pull the old wire out of the coil and somehow shove the new wire into place and voila? I included a picture below, as it looks like these are aftermarket coils.
At the bottom right, you can see a little of where the wire insulation is worn/chewed away. At the bottom center, I pointed to where the existing wire enters the coil. I don't see screws or tightening bolts. Do you just yank this out and push the new wire in or do you have to buy a new coil with the wire already installed?
